5 volt wideband input to rear 02 (pin 75)
tom04841
611
6
Jul 21, 2004
Rockland, Maine
Can this be done? I have evoscan, so I can change the formula to log the rear o2 signal as AFR. I just don't want to potentially hurt the ecu. If this won't work, What about wiring it into the signal wire for the MDP sensor? I don't care about CEL, so it all good.
This is on my 98 eclipse. I have been using evoscan for a month with no problems. I just need to find a way to log AFR along with the other engine parameters.
There is a thread about logging a 5v wideband signal through the rear O2 signal here somewhere. The only problem (if I remember correctly) is that it would only show a maximum of 1.2v.
Which wideband are you using? Evoscan can log some kinds through a serial cable.
Did you have to change anything to get evoscan to work? I tried mine on a 95 2g, but it wouln't go.
Thanks...i did search, but must have missed that one. I guess i will try it. Worst case if it does only read to 1.2 volts, I can change the output so that 1=20:1 and 0=10:1
Sorry to bring this from the grave, but did that ever work out for you? I am hoping to wire my wideband to the rear o2.
I believe in the Innovative WB you can change the output, but not posative.
I didn't look in your profile to see what WB02 you're running, but if you have teh AEM, you can set it to either a 0-5, 1-2 or 0-1 votl output. And isnce it's a WBo2 you will get accurate readings on whatever volt scale it is running.
I'm not sure if the rear o2 sensor can be changed to read a 0-5v input, but you could always run it in through the EGR or MDP sensor to allow 0-5volt feedback
