4g64 Need Help Identifying Part
smorton
113
Apr 24, 2009
Olympia, Washington
Would anyone car to tell me what this whole part is called and where I could get one? Its not the thermostat housing or water inlet. Its the whole piece where the upper radiator hose comes in, held on by 2 bolts, and everything below it; where the thermostat and that other piece are. Anyways, it would help me a lot! Thanks guys!
The piece the cap connects to or, rather, where the upper radiator hose connects to is called the "Cooling Water Outlet Hose Fitting" and is Mitsubishi part number MD366254. The piece that bolts to, or the piece that bolts to the head, is called the "Thermostat Case" and is part number MD188327. The piece bolting to that and leading to the lower radiator hose is called the "Cooling Water Inlet Hose Fitting" and is part number MD174467.
I can't seem to dig up any information on those parts numbers or where to purchase them... Could you help me out a little more please? LOL)))
JNZtuning.com, Mitsubishigraveyard.com (you'll have to call and find out if they have these), dealership, junkyard.
That is multiple different parts, including the thermostat housing and water neck. Can you provide a closer-up picture with what you exactly need highlighted.
Here is what I was referring to. As you can see this needs to be replaced. However, I also need to have this car running by tommorow; so I am calling junkyards now.... Unless you all know a 'ghetto' way to fix this temporarily....
Damn! I would try and find another one instead of attempting to fix this one. Galants have a 4g64 too, and their easier to find.
But does the Galants 4g64 have the same cooling system thats in my car? If so what years? I thought that their cooling system was on the drivers side, but I cant remember I guess...
And I cannot find those parts; I assumed google would have a link to a website with manufacturers parts numbers.
Google
Wow, you win most unique failure of the day!
The following Mitsubishi cars should have the same piece (MD188327, which appears to me the only one you need) as well; also, I'd stick to calling it a thermostat housing or water neck for a junkyard because any pick-n-pull is bound to have it all if they have one or the other:
1993-1998 2.4L SOHC Galant
1992-1996 2.4L SOHC Expo
The following Mitsubishi cars should have the same piece (MD188327, which appears to me the only one you need) as well; also, I'd stick to calling it a thermostat housing or water neck for a junkyard:
Dawh! Thanks buddy! I thought it was pretty unique as well. Thanks for all the support guys! Time so start looking for a Galant!
Oops. Make sure you catch my ninja edit. I don't rightly believe there was a 2.0L SOHC Galant, so best not to ask for that.
So even if the cooling system is on the other side of the head, that part should fit? Ive looked at the engine bays online and the radiator hoes and thermostat housing seem to be in different locations.
