Spyder 4g64 EGR Delete help
Nightmare2020
Apr 15, 2026
Aiken, South Carolina
Does anyone know proper procedure to do an EGR delete. I'm new to the forum and can't find anywhere?
Also why is the 4g64 more sought out?
Effectively, what you need to keep is the line from the fuel pressure regulator to the intake manifold.
Block the EGR valve at the intake manifold, cap the ports on the throttle body and P port on the intake manifold. That should be the gist of it.
I do not know if removing certain solenoids will throw CELs or not. If they do, you can keep them connected to the harness but disconnected from the vacuum system.
