775DSM
- 74
- 0
- Apr 14, 2009
Carson,
Nevada
So i am going to finally post my build so i can keep track of it my self. So far i have the rebuild on back order and i am currently stripping the block to nothing and getting everything ready to just drop in. No so far i have everything off the block including oil pump cranks head turbo and lines. Pistons are coming out now and then ill pull crank. I am trying to get rid of all my working parts that are coming off to make some extra cash to help purchase the rebuild. As i go i will post Before and after pictures of everything i clean up. I did how ever notice that the oil pump was busted at the top and needs to be replaced and when i pulled cylinder 4 the #2 ring was cracked in half and came off in 3 pieces. After i get everything cleaned up ill have a new car with 0 miles on the motor but 160k on the block. We shall see where we go from here. Right now i am putting the over sized pistons in and depending on if i spun a bearing or not standard bearings but if i spun one then im going over sized. Please feel free to post comments or suggestions as we go along. Now keep in mind this is my first build for any car.
Also you might want to post this in a blog, mods are trying to get us to post build ups in the blogs. Just a thought. Good luck with the build up!
