420A 4g63t swap on Eclipse GS?
Unfortunatly for you, It will cost WAY more money, Then worth.. To swap a 4g63 into your 420a hard top coupe, Car. The engine is "opposite" so to speak, So you would need to custom fabricate mounts in the enginebay, Along with getting a new trans, ETC. It would be alot harder, And cost alot more, Then just simply going to buy a 95 gst/gsx/tsi car that needs a bit of work, For cheap.
im going to have to agree with this just seel ## car and buy an older one that is turbo for cheap.
Thats way to much work chief just turbo your 420a. My little brothers turboed 420a neon smokes stock srt-4's. Just a thought.
It should be only the spyder non turbo came with the 4g64 correct?
In the US, Yes. There ARE 4G63 non turbo 2g Eclipses that are hard top/coupe in Europe, Though. They are also RHD.
I believe the n/t 4cyl 3g has a 4g64 (not exactly sure), Had one once, Boosted it with all BOLT ON parts from a 1g-2g everything were a direct bolt up (exhaust mani etc).
