teme
- 251
- 2
- Jan 25, 2004
Helsinki,
Europe
Anyone have done this ?
Change intake from turbo engine to n/t engine ?
Anyone ran dyno of how much gain and in what rpm area ?
-Royce-
yeah i was wrong. has any body ever put an turbo intake cam on a 90 laser? my power band now is from 3,800-6,200 after that it just sucks. i have a k&n, hacked air can, blocked EGR, gutted cat and stright piped from the cat back. so i dunno if it will help me out or not. does any body know of any free mods?
The intake cam does move your powerband around a bit. However, we just can't get enough air into our engines to get much power after about 6000 rpms. As for free mods, you sound like you've got the ones done that are worth doing. Don't touch the honeycombs in the MASS. That'll just lean you out, and you don't need or want that. Also, you might want to build a little heat shield around your intake and pull out that little jug under where the snorkel for the intake used to be. That'll get some cooler air into your engine since you'll be keeping engine heat out. Also, when your radiator fan blows, the air flows towards your air filter. Aside from that, there really aren't any other worthwhile free mods that you could do.
