4g63 N/T in Turbo Car? Anyone done this?
phunny
3,155
22
Feb 1, 2005
Pittsboro, Indiana
Friend of mine has a 92 TSI with a blown motor and an almost brand new 4g63 Turbo engine. He was asking me today if it would be a good idea. It's just his winter beater(even an auto), so it's not a racecar. Any opinions, comments, or better yet, how to's?
-charlie
SEARCH!!!
theres tons of info on this site.
search is your friend.
SEARCH!!! <-- click here
Since you're new to the site I'll explain it to you. Normally you do a N/T to Turbo conversion. Not just throwing a N/T motor in a Turbo. Thanks for trying but I'm guessing you haven't done this yet.
Okay, since some are still confused. I'm looking for guys running this set-up, and what boost levels they are running and for how long. And is there anything special the swap needed. If you are going to say search then please don't bother. If you just want to add a post count to your username go elseware.
8urwrx, thanks for the info. Did you ever turbo it?
Your asking if you can use an entire n/t long block to replace your busted turbo long block correct? If this is the case then yes you can swap it in. But you will need to use your turbo cams and be aware that the n/t has no oil squirters and higher 9.5:1 compression. This means that if you want the motor to last, you shouldnt boost much more than stock or drive it hard for extended periods of time.
  • For sale 4G63 Planetary Gear Sets ( for 1G & 2G )
    Planetary Gear Sets $175 a piece + shipping & paypal fees* fit 1G Auto GSX/GST * fit 2G Auto...
  • For sale 4G63 Motegi Traklite Wheels & Tires
    Motegi Tracklite Wheels & Tires $650 17X8 5X114.3 Offset +45 2 Toyo Proxes 235/45R17 Tires 2...
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
