4G63 Block oiling Mod problem.
jettster91
54
Feb 4, 2011
caledonia, Illinois
While I was performing the Oiling mod on my block. My carbide Bit snagged the corner, and hopped right up onto the ridge and cut right thru the tape i had laid and cut a little groove into where the gasket lays, Happened twice.. And you can see Via pictures.. Is this going to cause a gasket sealing problem? or do you think the gasket is going to seal into the little groove.. The groove on the right isnt terrible, not really worried about that one just the one in the close up. any advice would be great. i dont even know how you could go about repairing this problem.
Thanks.
It happens.. to all of us. The fix is simple.
Clean the bad area with brake clean, so it is oil free.
Mix up a dot of 5 min JB weld and pack it in there.
Come back in a few hours or the next day when it is fully cured and sand flush with a flat back board and 180-220 grit.
Clean the block again before assembly of all grit and dust.
The gasket will lay over it and the pressure from the front case will keep it in place.
For some added insurance a light brush of Non-hardening gasket maker on top of it when you install the front case.
