4bolt question
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
Alright i was gunna hit junk yard to try and find a 4bolt and i have a cupple questions.
1.is it all 2g cars that have 4bolts or 92+ cars
2. does the car need to be awd?
3. whats a easy way to spot to see if it has a LSD
4. if it doesnt have a LSD and mine does in my 3bolt will my LSD fit in the 4bolt?
thanks
4 bolt is in 92 and up, yea the car needs to be AWD, hence the name "4 bolt rear end" and for spotting a lsd, look in the driver door and you should see an orange sticker saying it, or on the rear end it should have a silver sticker plate looking thing that says it. at least mine does anyways. good luck.
You gotta make sure it is for a manual trans 1g tho, automatics had a different final drive ratio.
