420a Valve cover 8mm bolt broke end piece is stuck in block how can i get it out???
Its going to be really hard to not hit those threads. And when you get to the bottom there will be a "shell" of the bold still threaded in.
Well be careful and best of luck. Can you get a bolt extractor and try that?
You could try and use a reversed drill bit to extract the piece that broke off. We used this method a lot back in my HS auto shop and most of the time it works.
