420A 420a turbo kit
osvar
Jun 20, 2023
Winston Salem, North Carolina
I bought a cheap emusa turbo kit for my 95 Mitsubishi eclipse, I’m not looking for much power just for looks and noises LOL. But my question is how do I install it.
If this is on a never touched stock engine be prepared to rebuild in the near future. Also if that kit didn't come with an fmu I'd buy one and don't buy the Chinese knockoff. You'll also probably need fittings for the oil feed on the back side of the block. I'm not 100 percent since I buy everything separate.
I'd start by draining your oil and taking your exhaust off since the oil pan has to come off. You'll need to tap the pan for the oil drain. The oil feed for the turbo goes to the back where your oil pressure sensor currently sits. Next you could fit the manifold the kit comes with and mount your turbo to it along with the wastegate that is provided hopefully. I'd double check the wastegate and just make sure the lightest spring is in it just to be safe. Then I'd go and take the front bumper off and mock up the intercooler. Passenger side piping goes to the turbo, drivers side will hook right up to the throttle body. If it's not 420a specific you'll probably have to cut the piping to make it fit.
There's videos on YouTube that should get you pointed in the right direction. I beleive there's even a beginner tutorial on here for how to turbo a 420a. Just whatever you do don't give up it really isn't that hard. I wanted to turbo my rs back when I was 18 and before I did I researched like crazy and watched alot of videos.
