420a turbo build help.
built420
Mar 1, 2013
Arizona
So I'm doing a turbo build on my 420a. My car is a 1995 Mitsubishi eclipse but i have a 1998 built engine now the problem i ran into is my crank sensor doesn't work would i be able to use the one off the 98 and rewire it into my harness, and how would i do that?
Even though this is a DSM site your DSM is just the body inside its a dodge if you want the best help you should go to a 420A site 100% accurate info.
but if i was to say you shoud just hit up a local junk yard and buy the right one if your on a budgit if not sure t fits in the pocket LOL
WTF.. Kinda funny you should say that since there is a whole freaking section for the 420a on this here appropriate forum.. And to correct you once again it was Chrysler engine, not dodge. :rolleyes:
OP.. I have no clue to the answer, other then I'm sure someone here will chime in that knows more about it hopefully, whether its a "420a" or not...
