420A motor rebuild ?'s
stunnerracing
Mar 18, 2009
lancaster, Pennsylvania
i gave a 420 a motor that i am rebuilding. I am going to have it bored 20 over and all. Im adding a turbo kit and also nitrous. Can i use 2.4ltr cams on my head? What will i all have to change to used those cams? Please help.. thanks
im not sure about the 2.4 cams but what are your plans for the bottom end are you building it up at all or not? if your not i would and invest in some head work. are stock internals are not the best are cams and cam gears are pretty goo though and if you want you can go get the lifters and rollers out of a 2.4li turbo pt crusier there alot better in are 420a's andthere a direct swap!!!!
