420a interior electrical problems help!
2GEEZEY
777
Aug 6, 2009
Elgin, Illinois
Okay so this is the last of my problems(hopefully)
Dome lights. I know this as been answered but i haven't seen a case like mine.
When I open the doors, no lights come on( rearview, the lights in the door, and THE LIGHT IN THE CLUSTER?) and the ring around the ignition)
I have no idea how to get this to work again. I hope someone can help.
The bulb for the temp gauge may be burned out. you can easily test this by removing bulbs from another location, And putting them in that spot. (just to see if it's a bulb burnt-out), Or an actual problem. Obviously then if it's a burnt out bulb, All you hafto do is replace the bulbs burnt-out.
Okay I will do that tomarrow when I have time. What other bulb should i use to test it?
Any of the bulbs for any of the other gauges (fuel gauge, ETC), Just pop it in quick, And then push the cluster back in place and turn the lights on and see if it lights up. You do not need to put the 4 screws back in the cluster just to check if it lights up, Just push the cluster into it's position firmly.
alright ill check it out. thanks a lot guys.
I also check to see if there where dome lights by the door/floor, i didnt see any. I only see the one in the trunk and the 2 from the rearview
