Interior Electrical Issues. Need help!
2GEEZEY
777
Aug 6, 2009
Elgin, Illinois
Okay so my dsm decided to give me a few more problems to keep me busy on the weekend.
Lets start with the cluster.
The tacho,speedo,and fuel gauge lights work but the temp gauge doesnt.
and when i turn the key to ON only the battery and check engine light comes on. Then they go away.
Now none of the reading lamps or dome lights in the door work when doors are opened.
How do I get all the lights working again? I replaced all the bulbs, what else should i do?
Also, my power door locks suddenly stopped working. CAN SOMEONE HELP ME?
thanks, Ian
Check the fuses, relays. For the temp, check the sending unit. For the doors, check the actuators maybe they are done, also check fuses/relays for them as well.
Everyone will most likely say the same thing.
Thats what I was thinking. Just not sure. As for the doors, I hear the relay behind the radio going off, and the acuator. So I'm hoping its a fuse
Replaced ALL fuses. Still doesnt work.
Yeah its not...aren't new ones like 5 bucks?
anyways I fixed the temp gauge light, burnt out bulb.
And does anyone have a list of the lights in the cluster that are supposed to turn on and then go off when you turn the key?
