420a Belt slippage?
Pull the PS and A/C belt and see if the noise goes away. If it does, check the tensioner and A/C by spinning them by hand. If it doesn't go away, pull the Alt belt and spin it.
I was thinking, I spilled a little bit of coolant/water mix the other day. would that cause the sound if it got on a pulley?
Yeah, im pretty sure that's what it was. I recently over filled the reservoir and the over flow tube was pointed at a sloped piece of metal point right at the pulleys.
Thanks
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
