3rd gear pull, please advice
mitsumissile
155
4
Aug 6, 2003
Taipei, Asia
Here are my 3rd pulls. I think the timing is a little low. Please give me some suggestion. Thanks
The timing is low because the DA timing tables were modified. Were you having problems with the stock timing maps?
New log upload. I have problem when ever I shift, the knock will show up. Please give me suggetion.
Whats the air/fuel ratios during these pulls? Also your coolant temp is too high, at 206 degrees the ECU automatically will pull 1deg of timing, 224degrees will pull two degrees of timing...and I think 228 it will go into openloop. I seen for the most part of your logs your temps are in the upper 205+ degree area, I run my car without a thermostat and run a 14" and a 12" on a stock radiator in FL. weather, temps never go over 183 degrees, even during back to back pulls. Does this problem persist with the boost lowered to 15 psi?
