3rd and 4th gear issues confused and need lots of help
lmarinukjr
Sep 6, 2006
philadelphia, Pennsylvania
My car is a 97 gst fwd 5speed. The car has 1st and 2nd gear when you put the car in 3rd it goes in but doesn't grab same for 4th. unless you put it from 2nd to 5th then back to 3rd then it will go in 3rd and 4th. any help would be greatly appreicated.
If it's not grinding when it happens, it could be that the shifter linkage needs adjusting. When mine was out of whack, i couldn't go from 2nd to 4th (it just wouldn't budge out of neutral to go into 4th), i always had to go in to third before i went into fourth. Adjusted the linkage and now it's fine.
  • For sale 4G63 TD04HL turbo
    TD04HL turbo off a Mitsubishi RVR. This is a dsm bolt pattern turbo and is slightly smaller than...
    • MichaelSuch
  • For sale 1g 92-94 eclipse fender/door/quarter trim
    92-94 eclipse fender/door/quarter trim piece set. All clip towers intact. Passenger side quarter...
    • MichaelSuch
  • For sale 4G63 2GA AWD Auto Transmission
    2GA AWD Auto Transmission $750*** Pick up in 08080 NJ, you can also send a Freight carrier for...
  • For sale 4G63 70mm s90 throttle body - rebuilt
    Up for sale is a lightly used and correctly rebuilt 70mm s90 throttle body. This will fit all...
    • MindBlowin03
  • Wanted 4G63 1G JMF Intake Manifold
    Okay condition. Pm me with what you have.Ty.
    • oldkidken
