2nd Gen window rattle
coolwhip
104
Aug 23, 2004
Cincinnati, Ohio
OK everyone knows what im talking about, how when the window is rolled down and u close the door it rattles like a bi***. well i read the write up on this website on how to fix it, and i followed teh instructions to a T. i even used some great stuff expanding foam, closed the metal clam so there was almost no gap, got everything back together and it still rattles. i adjusted the felt cushions at the top of the door to the tightest setting as well. what could i have done wrong?? so far ive only done the drivers side. i really want to fix this problem. thanks for any help.
MY windows rattled at the point that the window 'frame' connected with the glass. The rubber (or whatever it was) had degraded and basically disintegrated.
I did the fix and it worked for me. BUT! There was also a loose bolt towards the rear part of the door that I had to fix as well. You might want to check that.
my window rattles so bad because it won't go up! my motor locked up and won't budge, but it's getting a new motor monday and nice tighting up so no more damn rattle! If you figure out the problem post it so i can correct mine to.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
