2G 2gNT Trans swap auto to man
Jcook2u4nv
Jan 10, 2022
Grasonville, Maryland
I have a 98 eclipse with a auto trans and want to swap a trans from a 96 donor. I know how to with all the mechanical parts. What do I need to know about the ecu? I'm not 100% sure what needs to be done there. What do I need from the donor car When is come to the electrical side?
Do I need to swap the whole electrical harness and ecu? I'm sure this has been brought up before sorry I can't find a thread that talks about this.
What specific sub model is your car? Turbo models have a different trans than the non-turbo models. The principle of the swap is essentially the same but the required parts will be greatly different.
Here's some useful threads I found using the search function:
If it's a turbo model:
If it's a 420a N/T:
If you have a 2.4 N/T Spyder, you'll need a whole new set of links. Which you can find through the search function.
