98primeredrs
- 0
- Jan 8, 2022
Adelanto,
California
Whenever I first start my eclipse it cranks and a couple of times and then will stumble to get up to idle then jump to the regular idle rpm. Any ideas on why it would be doing this. The car has never done this before and idles fine after it jumps to the normal idle rpm. I changed the rubber engine mounts to the polyurethane insert ones and it started doing this idk if that would cause this issue but im just throwing it out there incase. The car has a 420a and a 5 speed. Any help will be appreciated.
