420A 2gNT NVT350 Parts Availability
Cobe
Jun 15, 2021
California
What is the current market for parts for the 420a and NVT350? It seems that only a few sites list synchro and bearing kits for trans, and I have had a hard time finding normal wear/maintenance parts like oil pressure sensors, gaskets, etc, at local parts stores. The majority of my parts ordering has been through RockAuto.
I am trying to see if it is worth doing cosmetic modifications (Paint, wheels etc) to my 95 ESi. I do not want to put the money into that just to not be able to find parts to replace mechanical issues.
Also, this is not a big power, boosted, or racing build. I am just wanting a clean, fuel efficient, DD.
Any specific part you're looking for? I've been able to find most of the parts I needed for mine. If If I couldn't find something, I was patient until I lucked out at the junkyard.
Transmission Parts Distributors is where I bought the parts to rebuild my NVT-350. And RockAuto is where I bought my stock engine parts, plenty of sites still offering aftermarket stuff. I know RockAuto has the oil pressure sending unit. I'll drop a link if needed.
I can also help with any engine or trans maintenance. I've been down the road with both time and time again.
So, I believe my TPS is going out but all of the ones available state to change the throttle body, but no part number as to what throttle body. My current one is 4669032.
Sorry for the late reply. But you do not need to replace the whole throttle body assembly. You can replace the TPS only. It has 2 torx head screws holding it on. You can find a TPS pretty much anywhere. I recommend staying away from the Ebay products though.
