2Gb **Talon** aftermarket front bumper cover
kenamond
DSM Wiseman
3,225
67
Feb 15, 2006
Los Alamos, New Mexico
I searched for a while to find aftermarket, FMIC-compatible, Talon-style front bumper covers, but **everything** was an eclipse cover. I placed my factory order in October, 1996 for my Talon rather than an eclipse, because I liked the look of the Talon much better, and I still prefer that look.
My front bumper cover was damaged, and I'd like to replace it with an aftermarket 2Gb Talon-esque cover designed for an FMIC - Gawd, the front bumper cover for a Talon is sooo nice - anyone could tweak it a bit to make a really aggressive aftermarket part.
Anyone know of a place where I can find aftermarket ***Talon*** bumper covers designed for an FMIC? The 95-99 Talon emblem triangle imprint (in which to place the 2Gb Talon logo) in the cover would be prefferable.
I installed a fmic on my friends 98 talon and you don't have to cut much off for it to fit. If you like later I'll try to post a pic. The core was 18x7x3 if that helps and you can find a aftermarket bumper cover at www.squidskins.com btw the prices are can. dollar so you have to convert it to u.s. dollar
Got mine off e-bay used, pretty decent shape. It might be the only reasonabily priced way to go with it. I wish they made aftermarket bumpercovers for it. I surely would have done that instead, it ended up costing me under 280.00. You might check the classified adds, seems someone online here is always converting a Talon to a Eclipse. Might pick one up that way. Good luck.
Thanks for the responses. If I can't find an aftermarket unit, I'll just get a new (or used but like new) cover. I'd like to have a taller opening in the center to get more airflow to the FMIC, but it's looking like that's not an option.:|
Make my own? :) Not likely, as I've never done any fiberglass work.
looks like a used 2gb upper center section and 2gb talon bumper hacked to hell and back, then glued/glassed/plastic welded together.
kenamond said:
That's pretty sweet. The bottom half looks like the stock cover, but the top is different (no inverted triangular depression for the Eagle logo). Any idea how he did it?
I have no clue how he did it, but its awesome nonetheless. I believe its an ancient chinese secret. Though seriously, he said he didn't wanna be copied and I understand and respect that. But it does give you an idea just exactly what is able to be done with this bumper. Maybe it will give you some idea's.
