2gb Conversion Fog Parts
shiftdrift06
257
4
Jan 10, 2005
Houston, Texas
Hello, process of doing a 2gb conversion however have a question. What will I need to convert the Fogs over? I currently have a 96' Eclipse with Talon Fogs.
From the looks. I will need the fogs, brackets that mount the fog to the frame, and the bezels that go around the fogs.
Am i missing anything? Do the bezel mount to the bumper or the fogs, and are they easy to take off?
The bezels mount to the bumper. It seems as if you have everything, you might need to hardwire the fogs though like I did on my old GS.
IF I can remember correctly, all you need are the 2gb foglights. The mounting bracket on them should install on the 2gas. All you have to do is remove the foglight mounts from the 2ga fogs, and hardwire the 2gb fogs to the 2ga wiring harness.
Or if you want to do a clean job like I did, cut the wiring harness from the old fogs, put them on the new ones, so its factory style, clip the harness together.
Yes, those are all the parts you need. And yes, it is easy to take the bezels off. There is a screw that secures the bezel onto the bumper near where the top of the actual foglight is. There is also a a clip that retains the bezel in the bumper, but it will just pull out once the screw is removed.
