2g won't crank
DSMopar
615
15
Oct 6, 2007
Vista, California
Just finished my 6 bolt swap in my 95 talon AWD and it won't crank with the key. When I say crank I mean the starter won't turn over. Everything is connected properly, clutch switch is working fine (I can hear the fuel pump turn on) but it just won't crank. If I take the spade connector off and touch the starter hot to the spade it will turn over, so obviously the starters fine.
I did note there is one connector I haven't found anything for in the engine bay, and it is part of the starter harness... Any ideas?
That plug should plug in somewhere on your harness. Thats I think what gives the signal to the starter from the ECu harness. You need to find the other end on the ECU harness and plug it in.
What all did you connect to the starter. You should have a four gauge and a trigger wire. Do you?
That plug in your photo is for the starter solenoid. You need to find the other half, and it will turn right over. Just gotta find the plug, its on the harness.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
