2g with 1g cas issue quick question
joeberman01
Oct 27, 2010
Laveen, Arizona
K this should be an easy question. So if I was a dumbass an accidentally had my cas turned all the way advanced te car would not start right it would just be hard to turn over and may make some loud pops, right?
It will still start. You probably have it turned 180 degrees out. Pull it out and turn the shaft 180 degrees and re install it.
Yea I do last night and it started :) only problem now besides the geysers o fluid from various places LOL is that my timing in link is spiking from 8 degrees to 25 even 30 degrees not good no wonder the engine was getting soo hot so fast. I am thinking maybe it's where the wires are an it's getting a signal from the ignition
