2g Waste Gate Solenoid Restriction Removal
If you look under your intake pipe you'll see a little black cylinder like object with two vacuum hoses on it. if you take the hoses off and look real close you'll see on of the openings is slightlty smaller than the other. Look close, I thought mine was already out the first time I looked. Put a very small screw into the small one and pull.
ok little confuesing but i will look at it tomorrow when its light out, thanks, a pic would be perfect but ill see what happens tomorrow
