2g Turbo Sputtering!!!! Help!
xZuEsx
Mar 21, 2009
Manchester, New York
So i was driving the car had gone of probably say 20 miles and i turned down this one road absolutely no warnings i may add and when i went to give it some gas it sputtered at first i didnt know wtf was going on. So i kept driving it and got back home and it has gotten worse. Im going now to make a boost leak tester. I need some ideas please help get my car running properly again thanks guys.:banghead:
thanks guys it ended up have bad plugs and wires and then it ran better but not complete made my own boost leak tester and wala i found a leak fixed it and its all good.
Is it some kinda like a hiccup? Check your intercooler couplers as well, see if they're tightened. Like Viperbenz says, could be your spark plug. I just changed my wires and spark plugs just a week ago and cured my sputtering. NGK blue wires and iridium plugs are the way to go.
If it doesn't go away after this, then check your fuel delivery. The oem fuel pumps on the 2G's sucks, go for a 190 lph if your car is stock to mildly modded.
