kenamond
DSM Wiseman
- 3,225
- 67
- Feb 15, 2006
Los Alamos,
New Mexico
I need to take my oil pan off (I need to take a blow torch, sledge hammer, and tin snips to a zip-tie that's hiding out in there
I read the tech article on removing the transfer case on a 1g, and it looks the same as a 2g, but I wanted to make sure.
Also, I don't have a transmission jack, but I do have a floor jack on wheels, so I had this plan for pulling the transfer case without removing the driveshaft and without needing a 2nd pair of hands: bring the jack up to the drive shaft maybe a foot behind the transfer case, duct tape the shaft to the jack, unbolt the transfer unit, then pry it off the transmission output shaft. The jack should roll while I pry (smooth concrete garage floor), and when I get it loose-ish, I can let the jack carry the weight of the transfer case and driveshaft. When it's clear, I can slide the transfer case off the driveshaft which should stay balanced/taped on the jack. Then I can wrap a clean rag over the shaft end, lower the jack and set the driveshaft on the floor. I should be able to do this in reverse to help during the reinstall. Is this dumb? Others have suggested wiring the shaft to the undercarriage somehow, but I lack wire.
Thanks!
).I read the tech article on removing the transfer case on a 1g, and it looks the same as a 2g, but I wanted to make sure.
Thanks!
