2g timing map vs evo timing map
gsxeclipse97
1,255
Nov 7, 2004
Cedar Park, Texas
I don't know if I am reading this wrong but it looks to me that the 2g timing map is more aggressive than the evo 8. Is it just me but comparing them side by side the 2g looks like it runs more timing.
I haven't looked at them but I can you tell you that it probably does.
2g Dsm stock = 8.5:1
Evo 8 stock = 8.8:1
2g's run more timing stock because they have lower compression. Same reason stock 1g's run more timing that 2g's.
They also run more boost on a larger turbo with a bit leaner fuel map.
The stock/mod1 Evo tables are much better for running high boost on a small turbo. But if your looking for a really aggressive tune, the Evo GSR tune is a great place to start. I always base my tune off that and I run E85...
I used the ralliart tune as well but it killed my power in boost. Had to change it up some myself. It had me running 5-0° timing. Its a good tune to base with though.
^ Really? With the GSR tune you should see mid-high teens during WOT. I usually only end up adding a few degrees here and there.
I thought we weren't suppose to cross flash roms I went through and changed it by hand in the map itself. I know when I flashed new new timing map along with the tube I did made the car super slow.
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
  • For sale Walbro 255 for 2g
    Selling a new walbro 255 with install kit for a 2g. Prefer zelle for payment but can do paypal.
    • tyvo98gsx
  • For sale OEM EVO 9 Injectors
    Selling a set of OEM pink top 560cc Evo 9 injectors. Had no issues with these and they have been...
    • tyvo98gsx
