2g Speakers
jwahl16
427
3
Oct 26, 2009
Havertown, Pennsylvania
So i saw some similar threads but they didn't full answer my questions.
I have 95 2g dsm with infinity sound system.
I want to replace all the speakers. What are the locations and sizes of all the speakers?
Heres what i know:
Door Panels - 6.5" speakers (1 each side)
Back (1 each side) - size?
Any other speakers?
Also, is it straight wires going in to them or are there wiring harnesses i will need to buy to switch out speakers.
Thanks
I changed my speakers out in my 2g but i did not have the infinity sound system and the rears were 6x9's...but no speakers will fit in the rear without haveing to dent the space behind the speaker a little... There should also be a tweeter in each corner of the dash i think.
depends on the car, but yea the rear's can be either 6x9 or 6.5 inchers, dash speakers are like 3 inches, or something random but I cleaned those brackets out and mounted my tweeters in them. Some slim 6x9 aftermarkets will fit back there, i had a pair of rockford fosgates for awhile
By the way....
http://www.dsmtuners.com/forums/appearance-interior-exterior/326857-question-dash-speakers.html
http://www.dsmtuners.com/forums/appearance-interior-exterior/332745-factory-speakers-change-out.html
http://www.dsmtuners.com/forums/appearance-interior-exterior/8340-speaker-size-merged-1-7-a.html
Maybe I'm better at searching?
The rears are 6x9 and need to be about 3" deep or you will need to dent the area behind them to fit.
Also since I didn't see it mentioned, if you are planning on using the stock amp you need to look for 2 ohm speakers or you will be making another post as to why your stereo isn't loud anymore. If running a aftermarket amp, buy the best speaker you can afford.
More than likely you will need to cut the factory connector and use some sort of wire terminal for your connection to the speakers.
