UofACATS
- 707
- 18
- May 11, 2004
Tucson,
Arizona
At idle the car warms up normally.
I have the coolant offset a bit, so at 200º the fan cycles on normally until the coolant temps drops, then it cycles off.
If I get on the freeway, the temp drops steadily, down to the 160's. If I pull off and idle, the temps creep back up to normal.
Thermostat?
Thermostat?
I just never knew it stopped functioning correctly because I've always had a big DVDT cooler blocking air flow to the radiator, and the problem was always overheating (so the stat was always supposed to be open anyways - with the exception of warmup, but then again I live in southern AZ). Thanks for the help!!
