2G 2g p0170 code and temp gauge rising
Boosted2gdsm
Mar 27, 2016
Levittown, Pennsylvania
Hello this is the first time posting on here, so please excuse any "noobish" questions.
I'm having some problems and hoping someone could help out.
I have a 99 eclipse gst convertible, I'm currently having a code p0170 which is bank 1 fuel trim.
Well this code came on after I installed my after marketfuel pressure regulator (I'm gussing) because after installing the pressure regulator I noticed that my timing belt had been ripped off half way ( thank god it didn't snap) after I got the timing belt replaced along with belt , and everything that needed to be replaced , I noticed my check engine light came on after 40 miles of driving . Now I changed the upper oxygen sensorbut the code still came back on after resetting it.
My vacuum is good. When I'm at boost 15 psi it stays 15 psi , it doesn't creep or loose any boost.
MODS:
:255hp walbro pump , not yet rewired
:20g bastered turbo ( 20g compressor in 16g housing)
:full big front mount intercooler
:3 inch maf with Maft
:450 cc injectors
:after market fuel pressure regulator
:maft is blowthrough not recirc , no filter on turbo.
:boost gauge
I do not have a tunner nor a air to fuel gauge as of now.
Also is it normal for my fuel pressure regulator to drop to like 33 psi after I set the psi to 43 with the vacuum hoseoff and blocked ?
Thank you
In short and long term fuel trims you want to see under double digits. -10 or +10 but in cases it is normal to see just a hair over or under those
SO my 02 1 and 2 read between 0.100 to 0.800 ,
And
Fuel trim , is 0.08 and 0.08 on both.
Sometime drops into negative
Is this on your old regulator?
NO this is the one I have now, the after market fpr .
I never check the stock one because I never had any codes to even think about it.
Why are those codes normal ? I took pics of my scanner that's why I asked you if you knew how to post pics.
