Resolved 2G - No start after changing the engine
awandre
Mar 28, 2024
Mannheim, Europe
Hi guys,
I'm Andrew from Germany. Last weekend I changed the engine in my 2G because it was leaking oil out of the headgasket and I had another engine with only 80tkm.
Took the intake manifold from my old engine with everything attached to it. Now the car won't start.
Engine is N/A 4G63 7 Bolt 1997
What I've already checked, is :
Fuel pump only works when I give 12v to the check connector. I've also installed a new fuel pump so that's not the issue.
Crank Sensor has 12v and 0-4v signal
I've got spark, the car starts with starting fluid.
It's got fuel in the fuel rail, at the return too.
I tried changing the fuel pump relay and MFI relay, nothing changed.
I don't know what else to check.
The injectors are not opening and it's not giving power to the fuel pump.
On the electrical side, nothing changed, and the car run perfectly before i took the engine out.
What do you guys think ?
Thanks in advance.
Greetings from Germany
Solution
I tried plugging in my scan tool and ECU didn't communicate, the CEL didn't come on, so I swapped the ECU with one from my other cars, figured it would have some kind of security immobilizer, but the car started right up.
It's just weird how the ECU got fried while I swapped the engine, battery came out first.
I don't know, but that was the issue. Somebody can close the thread.
Thank you!
Hi guys,
Thanks in advance.
Cam sensor?
Thank you!
Solution
