2g MT Front engine mount bracket Part#?
Nanan
687
14
Sep 25, 2004
Houston, Texas
So with my rebuild I have discovered that my front engine mount bracket, the one that bolts to the trans has a nasty crack. This obviously needs to be replaced... I just built a new computer a few weeks ago and put Vista64 on it, well I tried to install CAPS on it and doh Vista64 says sorry your program sucks and wont run on 64 even in 32bit compatability mode so... I have tried to find the numbers via google searching but I have not gotten anything useful as of yet.
I need the part number for the front engine mount bracket for a 95 Eclipse GSX MT.
Thx
MD742364
That is the part number for the metal bracket that is secured by 2 bolts to the side of the transmission (under the thermostat housing). My son's was cracked too, however, we had it welded and it has held fine.
If you are talking about the motor mount that is secured to the crossmember, let me know and I will look up that number.
Here is a picture. Is this what you are talking about?
Cool, thanks for the reply, that is exactly what I was looking for.
The crack is from the upper bolt hole to the right side when facing the car, I think the top bolt came loose and let it slack a bit which can cause cracks quickly.
The rear engine mount was worse then the front, one whole weld had broken apart but I was able to weld it back together.
