2g maf on 1g tsi
red talon
54
Apr 23, 2011
billings, Montana
So I em wanting to buy a fp 4 inch intake but it needs a 2g maf to work so how can I go about swapping over to a 2g maf?
2G MAF in a 1G TEL/GVR4
Keep in mind the 2g MAF give the ECU a different airflow reading so you'll need larger injectors and/or some way to tune.
Do you have a Eprom Ecu?
As said you will need a way to tune for the other Maf.
Preferably from the ECU and not a Hack job of mixed matched parts or with a AFC... .
Mmm ok well im going to have to hold on then I don't have money for link now
In that case you sure don't need that intake. It is seriously over kill for most peoples setups. In fact it can be detrimental if your using that odd reducer as it causes turbulence which tends to reduce air flow.
I don't recall how much the FP intake costs but im very sure you could gain more by investing that money somewhere else.
