2g maf on 1g wiring
Ricerdude
Sep 19, 2003
Idaho Falls, Idaho
I work with a guy who says he bought an adapter wiring piece that is just plug and play with the the 1g harness to the 2g maf. I was just wondering if anyone has heard of this.
Thanks
Dustin
From the VFAQ: "get a spare 1G MAF from a junkyard, break the stock plug out of it, trim down the circuit board that the pins attach to (or cut the pins from the board), and solder the 2G MAF plug wires to the 1G MAF plug. This allows a pure plug-in solution and makes it a quick swap back to your 1G MAF if needed. If you do this, make sure to fill the space between the pins on the plug from the spare MAF with RTV, WindoWeld, or epoxy (you can wrap tape around the entire plug, fill with epoxy, then remove the tape after the epoxy has dried) so that the pins/wires can't touch if the adapter harness gets beat around. Make sure to test the adapter harness on the car before filling in the plug. "
I've never seen one pre-made though if thats what your asking.
Edit: If this is for the NT in your profile, it wont work, the 2g turbo mas isn't compatable with nt's. You will also still need some way to compensate for the lower Hz reading of the 2g mas.
