2g maf in 1g
Yes. But the plugs are different, just a little bit of wiring is involved
You can, but you would need to wire it up correctly. Look at the vfaq page for the how-to write up. If you do this then you would be running leaner and will need to adjust your a/f to make up the difference. I would upgrade to bigger injectors first or at the same time as when you install the 2g maf. Just saw your profile and it looks like you have an afc already. Install the 2g maf and start tuning.
His upgrades say he has 550s and a safc so he will be fine if he wires it right
thanks alot guys. very help full. i tryed to find that info everywhere and nobody seemed to know. thanks again
