2G Install Kit
HyperGSX
1,170
Oct 10, 2002
Schaumburg, Illinois
I need this kit to install any mitsubishi based turbo on my car, correct? I plan on installing a 14b on the car for the time being while eventually upgrading to a PTE 50 Trim, Will i be able to use the 2G install kit again after i upgrade to the 50 trim or will i have to buy another?
Yes, you will need some sort of install "kit" to put a Mitsu turbo onto a 2G (most importantly consisting of a J-pipe to route the compressor outlet to the intercooler), although a simple search would've told you that. You will probably be able to re-use some of the parts for your 50-trim install, although I believe that turbo will have a straight downward-facing compressor outlet, as opposed to the upward-facing one on the 14B. By the time you upgrade, however, you'll probably have a FMIC ready to go and should be able to get a complete set of piping based on your particular IC pipe routing needs.
