2G injector dual-firing tip?
2fast4
95
Dec 6, 2005
NorCal, California
We all know the nice dual-firing tips come with 2G cars:thumb: . The ? is since it
is dual-firing, each into both intake valve ports, doesn't the injector need to be
installed in correct position so each tips look right into each intake ports?
I have installed the injectors into 1g car but I didn't think to align it correctly. :coy:
If the dual pattern pintle caps are installed correctly the injector in it's normal position should be directing the flow at both valves. The normal position is the connector parallel to the head.
The injector itself only has one pintle, the pintle cap helps form two cones of spray.
Steve
Oh, I get it. Just be sure to turn the inj so that electric connector is facing the top of valve cover(it didn't matter for single caps but it does for dual-cap). Thanks:thumb:
