Firing order 2ga & 2gb
afireinside5976
32
Sep 20, 2007
Keyser, West Virginia
I have a 97 2gb car with a 2gb harness. My cas is a 95 2ga and my ecu is a 95 2ga. What would my firing order be? I searched but I can find anyone with a 2gb using both a 2ga cas and 2ga.I ecu.
4123 across,the coils from left to right, standing in front of the car.
Found it its on google if you type in 2g firing order.....
Unless wiring pins have been switched at the ECU harness connector or the coil pack connector, it should remain the same as stock, since you are using a matched CAS and ECU. Coil A (on left when facing front of the radiator) connects to cylinders 1 and 4, Coil B connects to cylinders 2 and 3. Which post of the coil connecting to which of the two cylinders doesn't matter.
The firing order is the order in which the cylinders produce pressure to act upon the crankshaft, it always starts with 1 no matter the engine. For all 4g63s the firing order is 1-3-4-2.
