2g GST OEM Ball Joint/Control HELP....
turbodsm18
675
4
Jan 26, 2005
816/417, Missouri
I am in need of the front lower rear control arms/ball joints (the boomerang style one). I was just looking at the CAP's program on MachV's website and according to it, you can just order the balljoint and not have to order the whole control arm.
http://machv.com/frsuarmandme.html
I have always been under the impression that you had to order the whole arm. Does anybody have an answer this.
Are you talking about part 40320A, which points to the ball joint end? That is the entire compression arm assembly, not just the ball joint. CAPS describes the part as "ARM ASSY, FR SUSP,LWR LH" for 40320AL. The ball joint is not available separately from the dealer.
If you were looking at 40317, that is just the boot, as wret mentioned.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
