2g "Ghost Pedal" Help
mattdev
349
Jul 15, 2006
San Antonio, Texas
I'm pretty sure I'm suffering w/ what RRE calls "Ghost Pedal".
here
My pedal ONLY sticks on very light pressure. I replaced slave and leaking clutch line, wich fixed a lot of my problem.
The thing that bothers me, is I have a 3 month old master cylinder. It's practically NEW! It was professionally installed also, and I have moved since it was installed. Is there another possibility, or am I in for a new NEW master cylinder?
Is it sticking or falling to the floor? I would try bleeding the clutch again.....
Dont forget to have a friend watch the reservoir for you so you dont suck air in ;-)
It's been bled correctly about 5 times now. And yes, it was just changed (ACT 2600). It will suck itself to the floor, it doen't simply stick on an engagement. If I give it light pressure, it will suck to the floor and stay there, all by itself. I haven't looked into a longer push rod, but that doesn't sound like the problem. I'll search it... Keep throwing in options. To make it perfectly clear, it is showing every symptom of "ghost pedal". I just don't wanna drop another 80 buks to not fix the problem.
I've never heard of "ghost pedal" but it sure sounds like air in the line. Sometimes, you need to remove the slave and hold it above the master in order to get every little air bubble out of the line. You can get the slave out easier if you remove the 2 front engine mount bolts, slip the clutch line underneath & out.
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
