2g Gauge Problem.
InfiniteGSX
3,182
16
Dec 10, 2002
Tijeras, New Mexico
I've brought this up a couple times with no response. So here's a video.
http://www.youtube.com/watch?v=ypqQlbUfB0c
Issue I've been having and haven't caught. Boost Gauge (yes I know its not a real gauge but it doesn't even work the way its supposed to), Oil Pressure seems to be working but I have one of the two sensors disconnected right now. Fuel Level, Well I have a full tank. How do I know? I physically checked and my fuel overflowed and poured all over the ground! So I have a full tank! It says I have little more than half. Coolant, Well this video was taken after a lengthy drive, heater is hot as fack! So it should be showing what the temp is. It doesn't. Hooked up and running EvoScan it shows the temp. No, the CEL has nothing to do with it, Thats for my Fuel Pressure Up Solenoid and no Emissions.
Wierd! I would start by pulling the whole gauge cluster out and putting it back in just to make sure there is a good connection on the back. Also on my old GST I put a similar guage cluster layout and I noticed the on some spots (fuel, and coolant temp) The needle was rubbing the over lay and it didnt let it move! Check those two th ings out.
Well these are the real AC S7's so they aren't really flexible enough to move and touch the needles. And I didn't pull the needles off (pita). I'm going to try another temp sensor even tho the computer shows the temp. I think it has something to do with the Harness. Because this is a brand new cluster from my new car. But the Harness is from my old car where it had the same issue on the old cluster. Except it had more issues before. Tach and Speedo didn't work before.
To me it seems like its a cluster problem, even more when all 4 gauges are inaccurate. Have you tried a different stock cluster?
Yeah just said that earlier. Problem was all the gauges were messed up. So I got a new cluster, a working cluster and it still has issues.
