2g front intermediate shaft help
spin1r6
76
6
Jan 15, 2012
Feeding Hills, Massachusetts
So I'm putting a formerly 6 bolt swapped 98gsx back together and put the 7 bolt back in it and a/c basically putting it back to stock. I bought this car as a shell and have had to acquire a boat load of parts for it. I know that 2ga and. 2gb have different a/c brackets but I don't know what is different about them. I believe I have a 2gb bracket but not positive. Anyway I tried to put the axles in today and the driver side intermediate shaft carrier does not bolt up, the hole on the axle bracket and the a/c bracket are not even close. The hole for the block lines up. What do I need to get to make it work? A different intermediate shaft or different a/c bracket? Axles came with the car and were on it when it was 6bolt swapped. Thanks for the replies.
