2G Eclipse/Talon Rear suspension compatibility.
cudadrt
110
18
May 9, 2008
Maryville, Tennessee
I have a 95 TSi AWD and am in the process of replacing all the bushings in the front and rear. I found a full kit from Energy Suspension but it only lists for an Eclipse and not for the Talon. From what I've read both cars are pretty much the same and was wondering if the bushing kit for the Eclipse GSX will work for my Talon. Also I want to replace both upper and lower rear ball joints and was wondering if they are offered? I read about the front working on the rear but is that for both upper and lower or just the lower? Any and all help is greatly appreciated and I have a press to do all the pressing on and off....just looking for the correct parts to use. Also looking to do this in a couple weeks as I am also installing a set of Eibach Pro kit lowering springs and a set of Tokico Illuminas and want to do everything in one weekend. Thanks!
The eclipse GSX and talon TSI AWD are mechanically identical so yes whatever you order for the eclipse will work on the talon.
