2G 2G Door Molding
Status
Not open for further replies.
CharlieRHFD
61
Feb 20, 2005
Rocky Hill, Connecticut
2G Door Molding needed for a 96 GST (NOT A WANTED OR CLASSIFIED POST), not the skirt, but the piece on the lower part of the door that flows between the inside ends of the skirt. I found 1 guy that has 2 off of a Talon, how bad will this look and/or will it work?
thanks :dsm:
Best? What the hell else would it be?
The sheet metal on all DSMs is the same, within a generation (1Ga, 1Gb, 2Ga, 2Gb). The plastics are styled to go together, but if this isn't obvious to your eye, it probably won't matter to you.
Status
