97-99 Side Skirts Door Molding Question
90turbotsi
244
4
Sep 15, 2002
Owings Mills, Maryland
Is the DOOR molding on a 95-96 Eclipse (GST GSX) the same as on a 97-99? (The actual part attached to the lower door) I know the side skirts are the same but wanted to see if the door moldings needed to be located as well.
Thanks!
The door moldings are the same but the side skirts are completely different. 95-96 are way different than the 97-99 skirts.
Good deal, yea im aware of the side skirt difference just wanted to verify the door molding. I may have gotten a steal of a deal on a 96 gsx and wanted to swap some parts to make it a 97+ (and I located the same color side skirts)
Actually the door panels are slightly different. The 95-96 door panel will stick out a lil in on the 97-99 side skirts. It snaps on the same way but It's not flushed in the back. I actually have a 95-96 door panel on the driver side of my 97 gsx. I'll try to get some pics up.
95-96 door panels stick quite a bit and look like poo poo with 97-99 ground effects, get a complete matching set of 95-96 or 97-99 to look decent.
