2g Coolant temp wiring Colors!!!!!
somdturbo
355
4
Feb 27, 2006
Lusby, Maryland
I am trying to get my coolant temp sensor for the ecu working after my 6 bolt swap. I know its the sensor shaped like a 'T.' Can anyone run out to their car and tell me what colors go on which part of the 'T.' All the wires are disconnected except the one with the single spade type connector, which i think it for the gauge. please help guys...
Pix would be awesome!!!
I can take a pic for you tommorw just pm me so I remember. I will do it right when I get back from work.:thumb:
I also need to know the location of this connector...I have a 6 bolt in my 2g also and I can't find the damn thing....PM me thanks
Well, pin 83 is the signal wire and 92 is the ecu ground wire for that sensor. pin 83 is a black wire with a white stripe and pin 92 is a black wire.
Pop a spade connector on the ends of the wires and connect it.
Im having the same exact problem as you, somdturbo has been a lot of help so far.
