2g AWD REWIRE
D_Eclipse9916
1,430
16
Mar 4, 2004
Vienna, Virginia
Alright so I installed my fuel pump and im ready to do the rewire and I notice there are 5 wires instead of 2 like in the fwd manual on the vfaq. Which wires am I supposed to cut and tie into? Mines a 98 Eclipe GSX.
The reason for 5 wires is because 2g awd have the pump and sending unit all in one assembly the with the harness facing you with the 2 pins on top and 3 on bottom. The top right and bottom right are for sender and the 2 on left and middle one are for pump. Turn on ignition but don't start car and power should have 12v and signal should have .5 and other is ground. Then continue with the facs on the 2g fwd to complete the rewire.
